Feature |
Product |
Release introduced |
Energy Efficient Ethernet (EEE) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4 Supported on fixed ports only Not supported on 5420F-16W-32P-4XE or 5420F-24S-4XE |
5520 Series |
VOSS 8.2.5 Supported on fixed ports only Not supported on 5520-24X or 5520-48SE |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
Fabric Engine 8.10 Supported on 7520-48XT-6C |
7720 Series |
Not Supported |
VSP 4900 Series |
VOSS 8.1 Supported on all fixed ports on VSP4900-48P and ports 1/1-1/12 on VSP4900-12MXU-12XE |
VSP 7400 Series |
Not Supported |
Energy Efficient Ethernet (EEE) supports the IEEE 802.3az standard for power savings in Ethernet networks for a select group of physical layer devices. A physical device that can support low power idle (LPI) mode is considered EEE-capable. Legacy devices that do not support EEE can be made EEE-compliant with an EEE-compliant PHY and an SDK version that allows the MAC device to interact with the PHY EEE functionality.
In a typical configuration, the EEE protocol communicates with the switch and the physical device to determine when to enter LPI mode during a period of inactivity, and to exit LPI mode when data transmission resumes.
EEE is supported only on copper ports that have auto-negotiation enabled on them.
